XL750 Spent Primer Upgrade
Non-Strong Mount Version
(for use without a Dillon Strong Mount)
$14.95
U.S. Orders only, International Buyers please use Ebay.
This upgrade is for the new Dillon XL 750 press. This upgrade creates a closed spent primer system that relocates the spent primers to a larger container under your bench. Just like my XL650 Upgrade this system uses a Funnel turned from billet aluminum and mounts using an plastic bracket, as the case is deprimed the spent primer will fall through the platform directly into the funnel and then be passed through the tube down to a suitable container (not supplied) such as a coffee can or soda bottle that sits under your bench.
This version is for reloaders without the Dillon Strong Mount. (Strong Mount version coming soon.)
| This system uses a Funnel turned from billet aluminum and mounts using a Plastic Bracket, as the case is deprimed the spent primer will fall through the platform directly into the funnel and then be passed through the tube down to a suitable container (not supplied) such as a soda bottle that sits under your bench. |
Upgrade Press Compatibility
This upgrade will fit the NEW Dillon XL750
Upgrade Includes
- Billet Aluminum Funnel
- Plastic Bracket & Mounting Screw
- 4' of Hose
- Bottom Hose Fitting & Zip Ties
- Pre-drilled Soda Bottle Cap
- Instructions <--click to preview
(To save Instructions Right Click the above link and click "Save Link As")
XL750 Spent Primer Upgrade (Non-Strong Mount Version)
$14.95
